Hi guys,
Doing some decorating and after removing the wall paper, found a nice gap between the plaster and pvc frame. It is 10mm deep, and 15mm wide at the biggest points. It's uniform all the way around. I was just going to fill it with some filler up to the pvc, and then use some caulk to seal/tidy the joining point. Would that be the best way about doing it? It's sealed on the outside and no drafts or oblivious gaps present to the outside from inside.
Any recommended fillers? I imagine it's a bit to large for standard crack filler from s tube?
Any help would be great guys
