we hit a stud a couple of times, but we just moved onto the next space,
Personally I think these are better
Screwing into a stud is much better than toggling off plasterboard
Used them as an apprentice, but I had the setting tool you mentioned, when i tried them a while back without the tool I pushed so hard the thing went through the board.I'm not a fan of those myself, if you need to take the bracket down to paint the wall, the threaded bit falls down inside the wall and you have to buy some more! I much prefer this style...
The downsides of these is that you need to know beforehand whether the wall is single or double plasterboarded, to be able to buy the right ones and you really ought to use the setting tool with them, so more costly initially. I've found that with the M6 ones, they will clench up properly without the setting tool, because the flange and the spikes are so much bigger than on the M4 and M5 versions.
Indeed, just a single number 10 screw has a shear pull-out load of 687lbs (311kg in English!!) when screwed into softwood.
Gaz
