Hi All,
I have a 240v Access Control Power Supply which outputs 12VDC / 3A via a built in relay, connected to a 12VDC electric lock (which has two solenoids & a 1n5408 diode in parallel across the terminals) and a 12VDC RFID keypad. I purchased these as a project to help me learn about RFID and pros / cons of installing in a domestic environment.
The Problem
Whenever I trigger the lock to open via the keypad (or just using a push switch) the PSU appears to trigger a protection and after engaging the lock for a split second, the PSU and keypad power down for a second then back on. If I replace the electric lock with a 12v AC bulb, it works correctly, the bulb stays lit for 3-4 seconds and the PSU doesn't power cycle.
After much trial and error, I stumbled upon if I connect the 12v AC bulb in series with the lock, everything works okay, the bulb lights, the lock opens and the PSU doesn't power cycle. After further trial and error with the components I had to hand, if I replace the bulb with another 1n5408 diode in series, connected with two wires using crocodile clips, the lock sometime works without the bulb. If I remove one of the wires with clips, the PSU power cycles again when triggered.
I measured various things with my multi-meter and this is what I found:
Relay voltage output = 11.8v DC
Solenoid resistance = 3.4 ohms
Crocodile clip wire resistance = 0.7 ohms
Bulb resistance = 1.0 ohms (its box states AC12V 50Hz 4.5W - MR16 275MD)
My Questions
1) What could be causing the PSU to trip?
2) Why would adding a bulb change that?
3) How can I solve this without using a bulb ?
Any questions or want me to test anything?
Help!!!
P.s. I tried another PSU (same type, different supplier) which resulted in the exact same problem.
The Problem
My Questions
Help!!!
