- Joined
- 10 Oct 2011
- Messages
- 16,396
- Reaction score
- 4,043
- Country
Really??If the pump is causing suction in the hw circuit, one way to dislodge things would be to close any isolator between the boiler and where it tees off between dhw and ch,turn off the boiler heat/electric, then run the pump on max (without the boiler) to circulate round the hw circuit. Then do your hammer tapping and cleaning out the filter etc.
Does it have a combined or separate feed/expansion pint on the hw pipework? If separate, The thing you have to watch is pulling in air through the expansion pipe or pumping over, you could always cap it *temporarily* while you're doing that pumping process.
However your cold water probably has more pressure and flow then your pump, so may be more effective if you can cobble that up.
Good luck!![]()
With the boiler being the 'neutral' point then the circulator will be de-coupled from the gravity circuit....
Google 'hydronic'..
