cooker circuit
Only on new installations. Regs are not retrospective.
Although regs are not retrospective, I think PBoD's statement (that it would be "a common recommendation") may well be true - particularly if the person doing the 'recommending' really believes that changing to a 'non-combustible' CU results in a significant improvement in safety (that is, if anyone actually believes that!).
All EICRs are written wrt the current version of the regulations. A "combustible" CU could merit a C3. In fact, unless you are of the opinion that the IET are in the habit of putting pointless requirements into the regulations, how could you argue that replacing a "combustible" CU with a "non-combustible" one would not contribute to a significant enhancement of the safety of the installation?
Indeed - and, as far as I am concerned, avoidance of an 'unclean' EICR is perhaps one of the few reasons for replacing an (otherwise perfectly OK) plastic CU with a 'non-combustible' one.
I'll leave you to ponder, and perhaps even answer, that question - perhaps at the same time as you are considering the matter of the addition of earth rods to all TN installations!
But metal CUs are NOT non-combustible. You yourself even posted a picture of a burnt out one.
Indeed not. In fact, as has often been said, nothing is 'non-combustible'.
However, for those whole believe that it matters, I suppose one would have to concede that metal CUs are 'less combustible' than plastic ones.
What is 'nothing' made of then ?
DS
On a new installation it would not be a recommendation:?: but it would be fair to say that on an existing one, it would be ;)
That is my point, when remarking upon existing installations (which is true of this topic), it would be common to comment on a fuse board/CU/DB that was not of a combustible type or not enclosed in a non-combustible enclosure. So we would remark upon that with a recommendation. Nothing to do with new installations or retrospective regs. I code 3 it, like I do when the board is not labelled correctly. But I ain't expecting the customer to ask me to change it or label everything up.
I thought it was quite humourous. Like when people say "Nothing rhymes with orange". It doesn't.
Very true.
If the comment had come from almost anyone else, I would probably have responded with a " :) " ! However, some people cannot resist any opportunity to have a dig at me so, even if their intent is actually humour, I can't trust it to be so!
