Being that sort of person - ie a pedantic one that actually reads stuff, in this case because I am switching tariff and there's a bit where you have to tick that to say you've read them - I was looking at the National Terms of Connection. Now there's an interesting bit about generators where it says :
If you install, or arrange for the installation of, small-scale generating equipment at the premises – which means one or more sources of electrical energy that have an aggregate rating of no greater than 16 amps per phase connected at low voltage – then you must inform us of your intention to use the source of energy in parallel with our network no later than 28 days after the equipment is commissioned. So long as you do this, you do not need our consent.
Fair enough - that's the rule that allows you to connect up to a 4kW PV array etc ...
But then it goes on to say :
However, if you intend to install or operate any other kind of generating equipment at the premises, you must contact us in advance and obtain our consent.
Now, I am certain that what they are meaning here is if you want to connect a larger generator in parallel with the mains then you need their consent, but ... that's not what it actually says.
Being pedantic, it seems to me that it says you can parallel up to 16A just by notifying. But if you install a changeover switch so you can run on the mains OR independently on a generator, then to my mind a literal interpretation of the terms means you need their consent regardless of size
Rather sloppy wording ?
