The pic below shows the bottom of a fill valve which is to be located within a toilet cistern.
The conical shaped black rubber section at the top of the pic would be within the cistern, and I'm fairly sure from the white plastic washer down would go on the outside of the cistern.
Does the flat black rubber washer marked with a red arrow go on the inside or outside of the cistern? It's not clear from the instructions.
Thanks.
Thanks.
