Ive only been able to get hot water when i put the heating on for some time now. So after some investigation it seemed a likely culprit would be a stuck diverter valve. So i got a rebuild kit and took it apart and fitted it back in the boiler. This dosent seem to have fixed the issue.
My diverter valve has valve ontop that pushes a rod up to activate a microswitch for the heating and a valve on the side that pushes a rod out to activate a microswitch for the hot water. The heating works fine but, when i turn on the tap for hot water i can see the rod being pushed out, so i know the diverter isnt stuck anymore but it dosent come out far enough to activate the microswitch (which dose turn the boiler on).
Its as if there there isnt enough pressure acting on it to push it our further but i belive my water pressure is at its highest or the spring is to stiff. I thought the rods of the new parts might be smaller but the parts i replaced are exactly the same as what came out.
any ideas?
any ideas?
