If 'C' had been a solvent weld, would the pan connector below fit into a solvent weld joint? Or does the pan connector below only fir into a "plain" end such as 'D'?All push fit, don't use solvent.
Cheers. It was a solvent weld bend I had wanted, that's what I asked for in the local merchants. The bend in the first pic (which I now know is a push-fit) is what I was given! I'll have to bring it back.Yes, that would work.
Push fit soil is usually easier to use and will allow physical/thermal movement.
Also consider slight alterations,with solvent there is none![]()
I was intending to use solvent weld soil pipe
Maybe he is hooked on solvent.you going to join the club![]()
When it comes to running through a wall, which the OP is proposing,
Well take their adviceI hear they're notorious for blockages!
Missed "in case".Well take their advice![]()
