- Joined
- 1 Mar 2009
- Messages
- 110
- Reaction score
- 1
- Country
I want to introduce a solution of Fernox DS3 descaler into my Tribune unvented cylinder which is heated by immersion heaters. I live in a hard water area. Water softener is not an option.
Here's what I propose:
1.Turn off electrics, cold and hot water. This isolates the system completely.
2. Drain the whole cylinder via the drain tap located at the bottom of the cylinder.
3. Make up the descaling solution as per Fernox recommendations.
4.Attach a tube to the drain tap spigot and introduce the descaling solution using either gravity or fluid transfer pump.
Any suggestions, criticisms etc welcome. So far as I can see, I have not interfered with the workings/safety of the boiler.
The only problem I can think of is that the drain tap might have some sort of non-return mechanism that stops the flow. In that case, I would use the 3/4 inch BSP hot inlet tap for the washing machine to introduce the descaler.
