Evening all,
I have a bit of a pickle to do with a neighbours lean to and i'm after a bit of advice if possible.
I have lived in my house for 8 years, it's a 2 up 2 down terrace where everyone has a single storey extension for their kitchens and bathrooms. My neighbours house, to the right as you stand looking out into the garden, has a lean to that goes from the extension over to the boundry, which is a wall.
I think it actually comes over the boundry if you were to use, but my main problem is to do with the construction of the lean to. It is made of 2 layers plywood sheets (1 on the inside of the lean to, and another on the outside with a gap inbetween), with an acrylic/plastic roof, there is no flashing from the house onto the roof, the lean to just butts up to the back of the house.
I have no idea how long it has been up, the house has been rented out since i've been here and was bought in 2005 so it could have been up before the landlady purchased the property, but does anyone know if it should adhere to any previous or current building regs?
Basically the inside wall closest to the lean to is now suffering from penetrating damp which I believe is due to the lean to. The ply wood that has been used has now pretty much disintegrated on the outside along with the timber frame. It appears that the timber framework is against the brick between the houses, and i'm not sure if they chiselled off the render or the render was done around it. Also the inadequate weather proofing is now cracked along the top and corner (which they only used some kind of sealant which has now perished) and I'm guessing water is now getting in and running down the channel between the houses and working it's way along my wall.
I would also like to add that the house next door has a very bad damp problem, a lot of it is on the same wall as mine as well as all along the back wall. Luckily I was friends with the previous tenants and they told me about their damp issues and allowed me in to see it as well as take pictures.
Unfortunately the landlady seems to have no desire to rectify things (the previous tenants told her and she did nothing, and I've mentioned it to her and no one has been round) and has put the house up for sale. I know I can start a neighbour dispute as I have discussed things with my home insurance legal team, but I'd like to know if the lean to should have been constructed with specific materials or built to a certain standard before I contemplate taking this avenue.
Sorry it's a long post but wanted to give as much info as possible.
