pretty much every joint is leaking in some way
I can see this one running and running.
ROFL, intentional pun?
I care and like to chuckle @ BG - was it FOC under a plan you have with BG ?Here's an update (not that anyone cares!)
Storage tank finally started leaking so BG agreed to replace it.
The reason the pump requires a min of 59 Gallons will be to avoid the pump emptying the tank. So if each tank us fitted to a different outeeth, that requirement won't be satisfied. Unless I misread the post.
When 3 tanks areally fitted in series, the volume of water below the connections will be disregarded in calculating the total volume; as it can never be actually effectually used, just turned over
If the risk of the tank becoming close to empty is a serious one then a float switch could be fitted in the tank to provide a warning of immiment loss of water. One step further would be to use the float switch to disable the supply to the pump before the pump can run dry ( assuming the warning is ignored )
Thanks guys
The outlet feed to the hot tank is NOT above the cold feeds (in fairness it wasn't on the old tank either). All the feeds are at the same level.
I may need to draw a picture to describe this better, but the hot feed to the cylinder comes from Tank 1, depending on which bathroom you're in the cold feed will come from the same tank (Tank 1) or one of the other two tanks.
So, actually thinking about it, the greatest risk is Tank 1 because that is feeding both the hot cylinder and one of the bathrooms directly...
this is currently being done as part of my British Gas Plumbing cover, so it was a Dynorod guy who came out, it was him talking about three tanks. .
Give up, Bernie. Get back to your agony aunt column. A flow switch is NOT the answer. Do it properly. Hot above cold, same
he actually goes on tho explain why it is a stupid idea![]()
Obviously the having hot feed taken from a point above the cold feed is the assured way to avoid the shower running scalding hot. But looking at the wider picture an enpty tank may have other repercussions such as ( but not limited to ) an air lock being created.
The float switch in addtion to the correct placement of hot above cold.
Perhaps I should explain things in clear language for those who need a full explanation.
