I'm about to install a thermostatic power shower in my upstairs bathroom, but my gravity fed system cold water tank in the loft isn't big enough (it consists of two 13.5 gallon tanks joined together by a short pipe at base level), to supply the flowrate that will be generated by a decent power shower (or, so I've been told by the manufacturers of the shower). They say I need a minimum 50 gallon water tank(the shower can supply around 18LTRS/minute at 0.1 bar pressure, so presumably a lot less than this at a working pressure).
Is this true or can I get away with with the 27 gallons we have at the moment(the hot water cylinder is big enough). The shower will be used a maximum of around 10 minutes at a time.
If I do need to upgrade my water tank, does anyone know if I can just "extend" my tank by adding another tank "module" connected by a further pipe at base level, to avoid messing around with the inlet and outlet pipework connected to the first tank?
Sorry to be so long winded.
Thanks in advance.
Thanks in advance.
