Hi all, I am modernising our bathroom on a very tight budget (just had our first baby) and am trying to prioritise what needs doing at the moment.
I have replaced the bath, toilet and sink, fitting electric underfloor heating and laid new laminate flooring over it. Its only a small UFH mat at approx 1.5m2 which is approx 275/300 watts
I have also fitted a electric 1200 x 500mm towel radiator with a 350w heating element (non thermostatic)
My flat is a 'coach house' style place with a 2 bedroom flat over 3 garages and the current wiring is as follows:
Consumer unit has 2 rails.......... the left rail is RCD 30mA protected and currently only has the sockets on it.
The right hand rail has everything else electrical within my flat, including what was the mains heat alarms x2 and mains smoke alarm on a 6a MCB!
The heat and smoke alarms are all being replaced with battery operated items which I have already have.
Its going to be a major nightmare trying to feed new cables from the CU to the bathroom and if I can get away without, it would be great because any chasing etc that needs doing and making good would go to the very back of the list of jobs and my walls would look a mess in the mean time until I could afford to have them made good.
So I have taken the heat and smoke alarms circuit, moved this from the the right hand rail to the left hand rail (which is RCD protected) in my CU and fitted a 16a MCB
The smoke alarm that was right outside my bathroom door is where I have terminated this cable and fitted a electrical rose (i think thats the term)
Out of this rose I have 2 cables goto 2 x Switched FCU with 13a fuses and then from these, 2 cables which drop down opposing bathroom stud walls (drilled through wall headers from the loft and fortunately there wasnt any noggins and the casbles both dropped to the dryline box's and out to the faceplates.
TL;DR:
Consumer unit (Left rail 30mA RCD protected rail currently only has sockets)
16a MCB
Rose
13a SFCU
Thermostatic Face plates for UFH and towel Rad
Standby works
Power on towel rad and it trips 30mA RCD in CU
When I turn the electric back on the standby light illuminates on both faceplates and all is fine............. I turn the towel rad thermostat on ( https://www.screwfix.com/p/kudox-electronic-heating-element-controller-800w/64054 ) and it trips the RCD in the CU
What have I done wrong here with my setup?
Will the tripping be down to the small cable used (its either 1 or 1.5mm T&E) originally for the heat and smoke detectors just not man enough now for the towel rad and UFH?
The distance between the CU (downstairs by my front entrance), up the wall (3m approx) across the loft to hallway where the cable terminates in the rose is (7m approx) and then to SFCU is (1m approx) then from SFCU to faceplates (2m approx)
I want to do this as properly as I possibly can without getting a professional in (at the moment)
I will be back in work once I have recovered (8/10 weeks) and will have the funds to get someone in who is qualified to Part 'P' to sign off on what i have done, but being self employed, off of work and with a brand new baby sucks and things are super tight at the moment, so any help or advice is much appreciated
Thank you and I will apologise now for getting terms wrong or if ive not explained myself clearly
RM
TL;DR:
16a MCB
Rose
13a SFCU
Standby works
RM
