Assuming that the cable will be buried in the wall, it has to run in 'safe zones', which means that it must run either vertically or horizontally from the socket and/or the fcu ('fused switch'). From what you say, that should be possible with an L-shaped cable run, one part of that 'L' being aligned with the switch and the other with the FCU.I have an existing double socket approx 6 inches to the side of where the curtain starts from. The intention is to take a spur from this double socket and add a fused switch to control some new lighting for outside. ... Originally I was thinking I could place the new fused switch directly above the existing double socket but the existing cables to and from the socket go directly upwards so I will need to place the fused switch to one side, which would be ideally be behind the curtain as the other side is not so convenient.
I agree.Many thanks for the further information, very helpful. .... From what you have said I think either of these 2 should be OK.
Yes, that sounds promising. Just to be sure, that 'Residual Current Operated Circuit Breaker' ought to have a test button on it. If you press that button, does it kill the socket concerned (as well as other things)? [don't try it whilst your other half is watching 'Strictly'I have just been looking at the main fuse box in the house (built in 1987). It's an MK unit described as 'Residual Current Operated Circuit Breaker' and each circuit has a trip switch on for each fuse, so assume that this is all OK re. your question about RCD protection.
It's obviously up to you, but it is really no problem having electrical accessories behind a curtain (I certainly have some). There would have to be something drastically wrong with your electrical installation for them to get hot, if that's what is worrying you.I feel uneasy about placing the new FCU directly behind the curtain, so think I will place the FCU the other side and keep away from the curtain.
You're welcome.I really appreciate you taking the time to help me with this. These forums are so very useful!
Thanks again for all the info. To confirm there is a test button on the RCD....definitely not to pressed while 'Strictly' is on!
