- Joined
- 28 Nov 2017
- Messages
- 33
- Reaction score
- 0
- Country
Hi, I've got a 3 storey (including loft conversion) terrace and am currently removing a conservatory that used to contain my kitchen and replacing with a proper extension. Loft conversion was done in 1994 (before I bought house) and there are no fire rated doors in the house so I do not have a protected staircase exit.
The kitchen will have a door to the hall and double doors to the living room, that then has a door to the hall. My building inspector tells me that the door to the hall needs to be fire rated before he will sign off for building regs but that I do not need to replace the lounge door.
The door between the hall and the kitchen will be in exactly the same place as an existing door, and both the old and my proposed new door are glazed softwood.
From reading the Part B document I contend that all that is required is that I do not make the fire safety 'more unsatisfactory than it was before' but the inspector disagrees.
Any thoughts on whether replacing my existing door with a fire door is mandatory or just advisable? (leaving aside the absurdity of replacing one door but not the other)
Also, I am very happy with my current set up of battery powered non-interlinked smoke alarms. The inspector says I need to add a heat detector to the kitchen and interlink it to other alarms in the house - is this right? From the Part B doc. it looks to me like the requirement is only for large houses, new builds or if I create habitable space with no exit to the outside? (which my new room will have)
thanks in advance
thanks in advance
