I was told by a builder that I could remove the ply as it’s not a load bearing material. I didn’t touch the vertical beams but I did remove the structure of the old window ledge (pic attached) and removed the insulation which was behind red plastic sheeting. The plan was to plaster bard around the beams and plaster over the old brick wall just to open the room out a bit.
