2 way switching 2 lights lounge / dining room
29 Jan 2009
Essex
Hi all,
As per the title I'm looking for a circuit diagram of wiring 2 lights one in each room to be controlled from either switch (one in each room) independently. I have found the below image bar the colour change which would seem the correct way of doing this. Or is there a better way to achieve this in a lounge / diner scenario. This would be a blank canvas looping in where required.
Thanks in advance.
On the original switch when changed instead of connecting com L1 you connect L1 and L2, with second switch it is three core cable like to like with original switch.
I'm sorry I do not follow what you mean........and the diagram there is for one light, I was looking for two lights and two switches. I'm guessing you just meant I was to double this up.
Essentially what I am asking is what I have shown in my first post (wiring schematic) the way it would be done or would this setup only be used on a stair / landing setup?
Doesn't matter if the switches and/or the lights are on different floors, the wiring is the same as the way you want it to work is the same.
It is not usual to have two-way switching for the hall light (with one upstairs).
Do you need or want that?
No I actually want it for the lounge / diner but this was the only schematic I could find..........just wondered if the wiring arrangement shown was the usual way of achieving this, ignoring the location.
Yes, it is the usual method.
A normal switch drop from light to one switch and three core (+ earth) between the switches.
yes so each back box has 3 incoming cables 2 x 3+e core and 1 x 2+e
Yes, for two lights.
Don't get the 3 core cables muddled up.
2 core to L1 & L2 (when Com, L1,L2; some switches are L1,L2,L3 instead), and
3 core to all three (the only important thing is the same wire must be connected to Com at both ends)
Yes so as per the pic I posted, I'll tape the ends to identify the 3 core, so not to get them muddled.
Is L3 the common in that instance you mention?
Why not? It certainly is in every house I have lived in and not all installed by me. The town house had all 3 floors switched on all 3 floors (original build)
Need? No. Want? yet especially with advancing years.
Well, to be entirely accurate, I would say because it is not necessary so most houses are not wired like that.
Ok. Perhaps bigger three storey town houses are different. They probably have a switch at both ends of the hall as well.
They are a minority and more 'usual' houses are not.
I don't see the relevance.
Do you mean so that you can switch on the hall light from upstairs before going down, or
can switch off the hall light from upstairs because you left it on by mistake when going up?
