Running plastic pipe through brick
2 Dec 2015
Evening,
I'm rerouting some domestic cold and hot water pipes.
I'll be using 15mm JG plastic pipe.
I intend to drill through joists but need to go through a brick wall into the utility room.
Assuming I need to sleeve it what material should I use? 22mm coper? 22mm plastic? Nothing?!
Cheers.
If you have some 22mm copper - use that -de burred as said (y) If you have to buy tube - use overflow pipe, cheap as chips.
Cheers.
I've got some 22mm copper in the shed so ill use that.
