Short version is it mad to cut 22mm copper into small sections to run through joists and solder back together?
Need to get heating 22mm F&R and 15mm hot/cold to a bathroom. really dont want them visible, Victorian solid brick walls and not very thick plaster on inside, so thinking pass through joists. the 140 year old timbers already have 2 badly placed (and occupied) notches in the top so i don't want to add more. 14 joists.
I want to run 22mm copper under this mezzanine floor before splitting to 15mm branches for each floor up and down, but properly drilling through the center of joists i'll not be able to get it in unless i cut the copper pipe into 15 sections and solder it back together, an option i've gone around in a circle and am back to thinking I'll do. (I'd have done it already in the time i'm wasting trying to think of a better way.) Some of the joins will be where i'd have taken tails for 2 rads but its still 26 extra solder joints for the 2x CH pipes.
Plastic option - I'm not going to use push fit. I can live with reduced flow in the hot/cold pipes to bathroom from having inserts in 15mm plastic pipe to use compression fittings so i'll use plastic for that.
But the 22mm plastic by the time i add inserts the ID is same as 15mm copper. I could upsize to 28mm but the holes start to get bigger, the pipe less flexible, the fittings expensive, but its an option. But in the end is a few compression fittings better than lots of soldered copper joins. Hidden and inaccessible under the floor
What would you do?
What would you do?
