Easing a corded curtain track system?
17 May 2013
I've got a new Swish aluminium curtain track fitted. It's been bent to fit our bay but the bends are quite shallow.
As soon as we hung our heavy (but inside the weight limit) curtains, it just stopped working even on the straight bit. We think this is because it has a sticking-out-bit to let the curtains overlapping, this means the curtain is pulling down and twisting the fitting rather than pulling directly vertical, causing it to rub.
I've seen people suggest using certain lubricants but I'm not sure to what purpose exactly... to leave a low-friction layer or to have a 'wet' lubricant?
We think we have some furniture polish, I also have some special WD40-PTFE spray and I wondered if that would be good?
sounds like you have insufficient supports to the rail. Fit some more.
I
That would be good - spray onto a cloth and wipe the track - the overspray can go everywhere leaving ptfe spots on walls :(
Why does it sound like that? This is with the curtain fully open, getting it to move at all. I see no flex on the rail itself. I do have some spare supports from another rail which didn't survive the bending process ;)
Have you gone the posh route- straight bit on the wall then a bend out into the bay then an in bend at the middle window, another in bend at the right hand window and finally an out bend to the straight bit on the wall? The picture on the packaging of my plastic corded track showed this arrangement but it didn't work at all (at the out bends the strings were cutting the corner giving too much friction).
Solution was to ditch the straight bits on the wall (so the track is solely in the bay with only in bends)- works nicely now.
Your PTFE spray will certainly help- I had some drainpipe lubricant to hand so used that & it made the action much lighter and smoother
