I'm trying to understand how proportional pressure works on the Alpha series pumps. This graph shows PP as blue lines:
You can see the PP2 line maxes out at 4m head at just over 1.5m3/h.
1. Does this mean the pump cannot operate in PP mode at anything over 4m head? What would happen in reality if you attached it to a system with 4.5m head (as an example)? At CP and fixed speed, the pump can still deliver 1.3m3/h, so my guess is it wouldn't just fail to operate at that head in PP?
2. In a fixed speed pump, the pressure differential at the pump INCREASES as the heating demand falls. In PP mode, the pressure differential DECREASES as the heating demand falls. This is according to the documentation. How does the pump achieve this internally? A pump has an impeller which spins at various speeds (fixed speeds traditionally, variable speed in an Alpha). The faster it spins, the more head it can overcome at any given flow rate. How does and Alpha pump REDUCE it's head at those same flow rates in PP mode?
