Wardrobe sliding doors
26 Aug 2013
Hampshire
I'm struggling to work out how to refit a wardrobe door. Not sure of the make but it's heavy duty and made to last except the bottom rail isn't! This plastic extrusion has split and the door won't slide without the thin plastic rail extrusion in place. Is there any way to replace this or any other solution anyone has?
Not at all, need dimension of track, height , width, profile type,
Finally got the offending piece in hand. Profile measures 9mm. At widest point and 6 mm. On the U channel section. Height 7mm. I suppose I could rout a wider section but that might make the door loose in the track I guess.
