I suspect that they are talking in pretty vague 'nominal' terms (which would therefore sort-of 'encompass' 240V!).Hi, If a solenoid coil is rated 220-230vac and it's used with 240vac supply regularly. Will it burn out easier than a 240vac coil?
But they do become "lazy" do they not? Its on a boilerI suspect that they are talking in pretty vague 'nominal' terms (which would therefore sort-of 'encompass' 240V!).
I suppose it might be theoretically true that it might 'burn out' very slightly 'more easily', but since they virtually never burn out, anyway, I don't think it's a real concern.
If I understand you correctly, 'becoming lazy' is due either to mechanical issues (springs, dirt, grease) or magnetisation of the core/armature/structure, and the latter of those will not happen with an AC coils. I can't really think of how the 'voltage rating' of the (AC) coil could affect that - but someone else might have other ideas!But they do become "lazy" do they not? Its on a boiler
If it does then it is illegally on sale in the UK.If a solenoid coil is rated 220-230vac and it's used with 240vac supply regularly. Will it burn out easier than a 240vac coil?
I don't think that's in any way pedantic.Being pedantic, "equipment" may have to work on that range, but I rather doubt that individual "components" have to.
Yes, quite possibly - or, alternatively, sometimes maybe not burn out whether the voltage be 220V or 240V. Either way, unless the situation were very marginal, I don't think that the different in voltages would make much difference.If the armature of an AC solenoid sticks and fails to enter the coil (due to being "lazy") then the coil will burn out whether the voltage be 220 or 240
