Hi, recently posted about using the DT92E as replacement.
Pleased to say it is working OK. The transmitter is now placed in our main bedrooom which is the coldest room in the bungalow especially at the moment with the very cold wind blowing directly across the field at the back. With the transmitter working there the temperature across the bungalow is maintained at an acceptable level.
My only question is that if I set the desired temperature to say 20.5 the stat will turn of the heating at a temperature just below that say 19.5.
Is this normal or is there an adjustment I need to make.
