Following on from another post where I thought we had low water pressure into our cold water storage tank, I think the problem is internal.
This is because the main supply to the kitchen tap seems to be at full flow. The feed to the tank upstairs used to gush when refilling, but at some point last year when they had to turn off the supply temporarily, it filled up slower than it used to. This in itself wasn't really a problem until recently when another switch off caused it to fill even slower. However, we've managed having given enough time for the tank to refill - trickling / dribbling with water.
Now, it's literally dripping, so it hasn't even filled up sufficiently overnight.
We think it is the float valve which has gone. Please see pictures attached. I've put a cassette tape to indicate size of the gap.
It's not a tank in the loft, but above the immersion heater. The space to work with is therefore limited and not easily accessible. The tank is of the older gavanised metal type.
How much would it typically cost for a job like this?
Thanks for any help.
