- Joined
- 27 Jan 2008
- Messages
- 23,733
- Reaction score
- 2,675
- Location
- Country
A stair lift has been unplugged, plugging back in the batteries would not recharge, quick cure new batteries, however I suspect the only fault with old batteries is over discharged.
Now I have an old unregulated battery charger, however 12 amp is rather over the top for a 7 Ah battery, but my smaller chargers seem to have a safety device built in which results in it displaying Err (Which I assume means Error) when I select charge.
I am using this Lidi charger however most chargers designed for small batteries are the same, in motor cycle mode limited to 0.8 amp designed for batteries 1.2 to 14 Ah.
Only way I can charge the battery is to connect it in parallel to my 75 Ah caravan leisure battery, it does not seem to want to charge them stand alone. It states Err shown if over 15 volt (or under 3.5 volt) now although 0.8 amp is not much, however for 7 Ah maybe still too high?
So what I am wondering is the battery simply faulty, or is the charger not suitable? As said batteries were working fine until stair lift switched off. But I have not really got much experience with such small batteries.
