We shortly having a new bathroom fitted and I wondered if an isolation witch for an extractor fan was essential? The en suite doesn't has one so I wondered what the regulation/advice on here was for it.
located about the bathroom door?
There will be varying opinions about "very helpful". Once every few years one might want to 'work on the fan' (usually to replace it), and, if there isn't daylight in the room, then an isolator would enable the lights to be left on whilst one did the work. However, that's a bit of a luxury, which is not available when 'working on the lights' themselves!Got you. Not regulation but very helpful?
Up to you. My usual method is have a deep (47mm) box for the isolation switch. At this point you’ll haveYes very true. With spots lights going in... am I right in saying there little value in keeping the lighting feed to the room in the centre? It’s better to have it near where it comes into the room and then all the spots chain from there?
I agree that some people might want such functionality (although it is amazing how rarely bathroom windows are opened, even when openable - maybe due to fears about neighbours with binocularsIt's also helpful to be able to isolate the fan if it is not needed when turning the light on, for example in the summer when normal ventilation through an open window suffices; or if the noise it makes is an unwanted distraction.
Indeed. If I subscribed to the reasons commonly given for having them, I suppose that, in my (several) rooms which have multiple wall lights and/or uplighters, I would have an isolator for each one, so that I could 'work on' in the light provided by the others!Fan isolators always struck me as a bit silly, over-designed for a functional switch, under-designed for an isolator.
I would also suggest that one probably has to think a bit before deciding that spotlights are a good way to light a bathroom.I would therefore suggest that one probably has to think a bit before deciding that a fan isolator really is "very helpful".
