Never heard of a 1/2 inch to 15mm socket then
Luckybags
You can’t get 15mm imperial fittings. They don’t exist and have never existed. If it’s bigger than 15mm it’s most likely 22mm which you can get imperial fittings.
So I cut another piece, and I still can't get the metric 15mm olive on. I don't have a precise measuring tool, but it looks like the outer diameter is about 15.5 or perhaps even 15.6mm. Where I cut the pipe now, I even struggle to get the compression nut on!
Is there a tool to 'squeeze' the copper pipe down?
And I saw that there are "imperial 1/2" olives". Does anyone know for what outer diameter of pipe they are? (My understanding is that half-inch refers to inner diameter, but my pipe seems to have quite a thick copper outside).
Thanks again!
Ah, just tried whether the pipe fits into the tee, and it does not! I think this is the point where I give up...
Copper pipe AFAIA, is always measured OD. Iron up and steel is ID.
I stand by my original comment.
Or get someone in with a set of pipe expanders. One size fits all then
