I have an open vented gravity system with no zone valves and a pump for Central Heating side only.
There are 2 tanks in loft, one is a cold water tank and the other a feed and expansion tank. Each of them have a vent pipe.
The boiler fires up when I switch on CH setting, but hot water cylinder tank is cold.
On HW only setting, the boiler does not fire up at all.
I suspect the Hot Water Cylinder Coil has an airlock.
I have attached a mains connected hose to open vent pipe on the Feed and Expansion tank and waited 30 mins. There were air bubbles at the bottom of the tank and I thought this would get rid of the airlock but doesn't seemed to have worked.
Any thoughts, Should I have waited longer than 30 mins ?
J
J
