- Joined
- 2 Apr 2005
- Messages
- 29
- Reaction score
- 0
- Country
Gravity heating system, with Potterton boiler, central heating works fine, but hot water side appears to have an airlock. Feed from boiler up to hot water tank is very hot, so water being pumped up okay, but exit pipe from the hot water tank is cold.....so it isn't flowing through, and therefore not heating the water in the tank. Note this is not the hot water being supplied to the tapes, the problem is in the pipes carrying the water that heats the water in the tank.
About 12" from where the lower pipe exits the hot water tank there is a 90 degree, downwards elbow, which is sometimes home to an airlock. Swift tap on the pipe usually sorts this, but today I can't seem to shift it....does anyone have any suggestions?
Have checked motorised valve - working fine, and I know the thermostat is working because the boiler is firing up.
Someone suggested I try turning the hot water tank thermostat to max, with the heating switched off, to see if this cures it - bit wary of this approach, how long do I leave it to see if it clears the problem?
Any advice much appreciated !
Paul
Paul
