I’m having a nightmare trying to get waste away from a planned en-suite the far side of the house from the existing stack.
Due to a sloping site, three levels within the building and an open plan layout I have two options:
1) Install a pumping station underground to take the soil, macerate and then pump it to the far side of the house.
2) Run a soil pipe 7m along the inside of the house, through the external wall, turn 90 degrees and then continue along the external side wall for 12m before dropping down into the existing stack.
Whilst I’m much more comfortable with the pumping station than an individual macerator in the bathroom is like to avoid it if possible.
Is a long run along the external wall a consideration? I can easily find a fall of 25mm per meter inside and outside with the one right angle in between.
