- Joined
- 30 Aug 2017
- Messages
- 46
- Reaction score
- 1
- Country
So I've just had a new bathroom fitted - all very nice and all that, but the water pressure in the sink, bath and shower is way down on what it was prior to fitting. Initially when I first turned the tap on upstairs (the refit was done whilst I was on holiday so this was my first use of it), the water was literally a dribble...as in barely anything coming out at all. Strangely enough, it has improved over the last week without anything being done, though it is still down on what it was. As a rough guide, before the refit I could fill a 1 litre bottle from the sink tap in roughly 8-10 seconds. Now it takes ~20 seconds. I never really used the bath before the refit so I can't say what it was like previously, but again it seems to be lower than I'd expect (or hope for!). The shower as well is usable, but it also has lower pressure than previously.
There wasn't any major pipework done - the sink and shower are in exactly the same location as previously so basically the same pipework. The main difference is that the heated towel rail was moved from one side of the room to the other and the bath taps are now at the opposite end of the bath to where they were before.
I've spoken to the fitter who said he's tried everything he can think of, including checking the stopcock in the street to check it was properly open. It had actually seized so United Utilities are going to be fitting a new one and will measure the pressure at the property boundary once that's done...although it could take up to 30 days for it to be fitted.
Have to admit, I don't think it's the mains pressure that's a problem though as the downstairs tap in the kitchen is fine, as is the outside hosepipe in the back garden.
I know diddly squat about plumping so I was just wondering if anyone could maybe give me a few ideas as to what might be the problem or things to check/test to see if it's possible to narrow down the issue? It is weird how it improved from being a dribble to start with to now being kind of usable (although way lower than it should be). I did wonder if it was some kind of airlock...? But then again I thought an airlock would prevent flow altogether? Or maybe some kind of blockage/sludge in the pipes somewhere (though I'm really hoping not as that sounds like it would need the brand new floor to be ripped up in order to resolve!
Any pointers or ideas would be very gratefully received...
