Hi, a question about installing these. I have 2 - for 2 showers, I would like to install both in the "system A" configuration:
This would mean splitting the existing 22mm cold supply to my megaflo into 2 separate 15mm - one to each recoup and then to the respective shower and rejoining to enter the cylinder.
My question is:
Will the surplus preheated water from the pipe supplying the shower that is in use refill the cylinder or will it refill from both pipes equally - in which case I'll have to keep the single pipe and install one as system A and the other as system B (preheated water only goes to shower).
Thanks.
My question is:
Thanks.
