Stripping the bathroom before having it redone. I've shut off both the hot and cold water valves to the bath but there's still a slow stream of water coming out of the tap. They're pretty tight and i'm hesitant to turn them any tighter in case something gives. Having read around it seems these valves can be rubbish?
Should I drain the system or can I get away with pulling off the current fitting then going straight on with a stop end?
