Rj11 broadband connections.
4 Jan 2009
Herefordshire
Here is the exam question:
I have a BT master socket with broadband face plate. However I need the router slightly further away.
I would therefore like to install an rj11 faceplate where I want the router. And connect it to the designed AB connections dedicated for this.
How do I wire it up? I know I use the center 2 connections on the rj11. But which way round?
A goes to 3.
B goes to 4.
I don't think the polarity matters nowadays, there no guarantee that your incoming line is the correct polarity in the first place!!
edited, because I had it backwards!
Thank you.
Where did that nice diagram go?
I will check it before use.
Yeah I notice phones use the outer connectors.
It was a bad one showing the front of the connector, i.e. they had the numbers going the wrong way, so I removed it.
Checking the cable shouldn't really matter actually, I assume you'll just be re-using the original RJ11 to RJ11 lead that you already have, which could well already be a crossover lead, but will of course be 'correct' if that's what the router wants.
Well I'm happy that the router cables I have looked at are consistent. EE / Sky / Netgear
The RJ11 outlets don't appear to have a standard though! for routers.
Having measured 3 micro filters and 1 face plate there does not appear to be a standard method.
Obviously all use the middle 2 pins. (routers)
@AndyPRK , sorry, I had them backwards. I have edited the reply earlier.
It had been bugging me as to whether I had remembered it correctly, so I checked earlier with a Mk2 faceplate and A is definitely 3 for an RJ11. They show continuity, as does B and 4 of course.
I was confused because the colour code changes from BT's A & B colours, to the CAT5e style 'swapping the centre pins over'!
Even more confusing that the Mk2 and Mk4 ADSL plate will also accept an 8P8C connector. :eek:
