I know a guy who was fed up with having cold water at the basin tap having a long dead-leg pipe. He put an instantaneous electric single point water heater under the basin fed from the hot draw-off pipe. He got quick hot water, then when hot water came through from the cylinder the electric heater would switch out. It worked out cheaper in installation and extra gas consumption than having a DHW primary loop. His DHW draw-off went via the basin and down to the kitchen. So the one electric unit did both. But not as quick in the kitchen as in the bathroom, but still a lot quicker.
I would've expected that unit to be rated for mains inlet pressure. Rather than low pressure from the cylinder.......
Mmmm I smell more BS
