Yes, I was going to do that but still deciding on which slabs. We would like smooth and not riven but they're not cheap are they !!!!Draw out your slabs to scale making a larger area, then line out the dimensions to scale and then you will know how many slabs and the No of cuts.
I should have thanked you for that so thank you now. Is there any chance you could tell me what the angles are please ?Then you were incorrect when you said
You got your angles to pot!
As my CAD drawing illustrates.
I presume that is some kind of advanced drawing/design software. I do have a telegraph pole and a panel fence to contend with but I have put a set square on the two bottom corners and I can make them both 90 degrees and so I now have a trapezium instead of my original irregular quadrillateral. Much less cutting and less slabs to buy possibly. You Sir have made my day. Thank you. Would it be possible please, using your software, to make the two bottom angles both 90 degrees. That in turn will increase the length of the bottom line (currently 4295) and also the length of the two diagonals. It will also alter the length of the two sidelines but only marginally. The one constant has to be the top line, currently 5200.Sounds like someone needs to download SketchUp ......
