No.Do the sockets look the same?
What makes you say that?No.Do the sockets look the same?
Have them both powered from the socket circuit, but one of them switched by a contactor operated by the light switch.One accessory will be connected off the socket circuit.
The other accessory will be connected to the lighting circuit.
i read it as a dual mount box, with 1x single socket and 1x 5a socket fitted or something similar fed fom the lighting circuit
yes, yorks has read it correctly.
How (unnecessarily) complicated! As has been said, connections between CPCs of different circuits are common - and, indeed, if everything is in steel conduit (all the way back to CU/DB) then the CPCs of all circuits will be connected.Have them both powered from the socket circuit, but one of them switched by a contactor operated by the light switch.
Missed that.yes, yorks has read it correctly.
It was a suggestion more aimed at not having a socket on a lighting circuit than the cpc issue. NB I'd missed that it was going to be a BS 546How (unnecessarily) complicated!
I suppose that depends on what one regards as elegant but, as I said, it would certainly be unnecessary, and unnecessarily complicated. If you really wanted to get him going, I suppose you could have that lighting socket controlled by a smart phone (which I doubt he would regard as elegant)I don't think I'll be using a contactor to switch about 10W of LEDs. I don't think that would be elegant!
