Stop cock only giving half a turn
  • Thread starter Thread starter Coniferman
  • Start date Start date
C
Coniferman
I have a standard looking stop cock under the sink. Probably 30/40 years old. I remember it always being a bit hard to turn but it always used to turn around multiple times. It will now only turn about 180 degrees. This does seem to give a full range from off (if quite tight) to fully on.
To be honest, it has been like this for a while. Should I be overly concerned about getting it fixed? Will it likely need an entire new tap or just a replacement mechanism? Is there a possible fix - like loosening the nut temporarily? Thanks.
It's one of those things someone may need someday in a hurry like a fire extinguisher, best to get it changed now before the water is lapping around your ankles.;)
Yeah. Change it. It is not a fine wine.
If changing is awkward, fit a 2nd one immediately after. And stop using the 1st
If you slacken the gland nut it might turn. If it does, put silicone grease on the shaft and turn it fully both ways a number of times, till your confident it will work easily in an emergency. Retighten the gland, but don't overdo it.
