Hi, I am replacing my current thermostat and timer which are danfoss, my boiler is an Ideal logic and I believe it’s a Y plan ( I could see only 1 motorised 3 way valve at the pump and hot water tank). I assumed it would be an easy enough install but find it hard to trace back wiring there is also an electrical junction box at the hot water tank. My query was where does the heat on wire feed back to the pump or the timer, I was going to use the live and neutral from the thermostat to power up the nest. Please see enclosed pics, the second last pic is the wiring to the timer the 4 wires that are in the terminal block ? and coiled up behind there is a brown and black with bare ends ? Any pointers would be greatly appreciated.
