Yes, something like them. Only not from that seller. Did you read his feedback?
That's interesting. Thanks. I've just had a look at the concrete blocks and bricks for sizes...http://www.huwsgray.co.uk/bricks/imperial-reclaim-commom-wirecut-brick-73mm.html
Local to you, they may have others similar.
If building wider wall make it 330mm wide and rather than block use cheaper concrete brick inside,will make it easier to bond together using tiewires.
Surely for a garden wall you'll just build the 2 skins and infill with a weak concrete incorporating your 250 old bricks broken up a bit and some tie wires to tie it all together. What you save on buying blocks/bricks for the middle can be put towards suitable facing bricks laid the correct way. You can infill the middle yourself when the brickie has gone home and save even more money.
I suspect that when you get a price for the labour that a few hundred more or less for material will fade into insignificance anyway.
