Concerned about BCO’s advice (floor insulation install)
15 Jul 2018
I have replaced all ground floor joists due to damage and the next stage is to insulate them now. The building control officer came round to inspect mid job and advised to install 80mm celotex between our 95mm joists and leave the extra 15mm gap at the top of the insation. (Detached Victorian (1890) with no wall insulation or cavity)
He didn’t mention anything about vapour barriers or taping between where the joists and insulation meet to keep it sealed. He even advised to not fill the gaps between the wall and outer joists. I’ve seen many comments about filling this gap with insulation or sand/cement to prevent drafts.
Is his advice good or should I be taping the gaps?
EDIT: the subfloor is very well vented around the whole house with an original DPC and no signs of rising damp. Some corners of the subfloor are wet after heavy rain fall but remedy work outside with drainage should help this.
So the BCO has asked you to install the insulation, but leave an air gap between the insulation and the underside of the flooring? given there is a well vented underfloor area, I am confused?
Surely if there is an air gap as above the benefit of the Insulation will be lost when the air whistles along between the insulation and the underside of the flooring??
Ken
I dont understand the logic....
I would be thinking flush to the top, foil tape and foam around edges.
I am with Notch7.
Any gap between the insulation and the underside of the floor wi totally negate the benifit of the insulation, because in a well vented under floor the draught will drag all the heat from the room above???
Ken
Ken
I am with Notch7.
Ken
I thought his advice was odd...
I wanted to use 100mm Celotex but BCO said 80mm was enough. Given my joists are 95mm, I would have to make up the 5mm on the underside with batons which shouldn't be an issue.
Could filling the entire joist for insulation cause any issues with preventing the wood from getting ventilation? Or is having only the underside of the joist enough?
Any thoughts on using expanding foam around the edge of the joists to the wall?
If you can look on The Planning Portal - Part L conservation of fuel and power - Approved Document L1B -Accredited construction details - under masonry
cavity wall insulation you will see detail MC1-GF-03 timber suspended ground floor which should answer some of your queries. Discuss it with the BCO.
If you can get hold of a copy, this book:
Stirling, C. (2002) Thermal insulation: avoiding risks. BRE Publication. (p63)
also advises that PIR board insulation should be level with the tops of the joists, to avoid heat loss through air circulation
directly under the floor boards.
Your bco seems not to be up to speed on this by advising something sub-optimal.
That makes sense to me.
And, as Ive just done a garden cabin with PIR, flush to the top, Im rather glad its not wrong :)
