    Dismiss Notice
Concerned about BCO’s advice (floor insulation install)
Discussion in 'Floors, Stairs and Lofts' started by ToastyToes, 12 Dec 2018.
  1. ToastyToes
    ToastyToes
    15 Jul 2018
    199
    Thanks Received:
    8
    Country:
    I have replaced all ground floor joists due to damage and the next stage is to insulate them now. The building control officer came round to inspect mid job and advised to install 80mm celotex between our 95mm joists and leave the extra 15mm gap at the top of the insation. (Detached Victorian (1890) with no wall insulation or cavity)
    He didn’t mention anything about vapour barriers or taping between where the joists and insulation meet to keep it sealed. He even advised to not fill the gaps between the wall and outer joists. I’ve seen many comments about filling this gap with insulation or sand/cement to prevent drafts.
    Is his advice good or should I be taping the gaps?
    EDIT: the subfloor is very well vented around the whole house with an original DPC and no signs of rising damp. Some corners of the subfloor are wet after heavy rain fall but remedy work outside with drainage should help this.
  2. Sponsored Links
  3. wwwebber
    wwwebber
    5 May 2004
    435
    Thanks Received:
    24
    Country:
    So your floor joists are only 95mm ?
  4. ToastyToes
    ToastyToes
    15 Jul 2018
    199
    Thanks Received:
    8
    Country:
    95x75 with 1m clear spans due to honeycomb walls at 300 centres. Very strong and sturdy.
  5. KenGMac
    KenGMac
    24 Aug 2010
    3,852
    Thanks Received:
    746
    Ayrshire
    Country:
    So the BCO has asked you to install the insulation, but leave an air gap between the insulation and the underside of the flooring? given there is a well vented underfloor area, I am confused?
    Surely if there is an air gap as above the benefit of the Insulation will be lost when the air whistles along between the insulation and the underside of the flooring??
    Ken
  6. Notch7
    Notch7
    15 Sep 2017
    25,297
    Thanks Received:
    1,791
    S. Uplands
    Country:
    I dont understand the logic....
    I would be thinking flush to the top, foil tape and foam around edges.
  7. KenGMac
    KenGMac
    24 Aug 2010
    3,852
    Thanks Received:
    746
    Ayrshire
    Country:
    I am with Notch7.
    Any gap between the insulation and the underside of the floor wi totally negate the benifit of the insulation, because in a well vented under floor the draught will drag all the heat from the room above???
    Ken
  8. Sponsored Links
  9. ToastyToes
    ToastyToes
    15 Jul 2018
    199
    Thanks Received:
    8
    Country:
    I thought his advice was odd...
    I wanted to use 100mm Celotex but BCO said 80mm was enough. Given my joists are 95mm, I would have to make up the 5mm on the underside with batons which shouldn't be an issue.
    Could filling the entire joist for insulation cause any issues with preventing the wood from getting ventilation? Or is having only the underside of the joist enough?
  10. ToastyToes
    ToastyToes
    15 Jul 2018
    199
    Thanks Received:
    8
    Country:
    Any thoughts on using expanding foam around the edge of the joists to the wall?
  11. If you can look on The Planning Portal - Part L conservation of fuel and power - Approved Document L1B -Accredited construction details - under masonry
    cavity wall insulation you will see detail MC1-GF-03 timber suspended ground floor which should answer some of your queries. Discuss it with the BCO.
    • Thanks Thanks x 1
  12. ToastyToes
    ToastyToes
    15 Jul 2018
    199
    Thanks Received:
    8
    Country:
    Lovely. Page 3 if anyone else is wondering.
    https://webarchive.nationalarchives...ry_external_wall_insulation_illustrations.pdf
  13. tony1851
    tony1851
    23 Feb 2012
    10,342
    Thanks Received:
    1,566
    Manchester
    Country:
    If you can get hold of a copy, this book:
    Stirling, C. (2002) Thermal insulation: avoiding risks. BRE Publication. (p63)
    also advises that PIR board insulation should be level with the tops of the joists, to avoid heat loss through air circulation
    directly under the floor boards.
    Your bco seems not to be up to speed on this by advising something sub-optimal.
  14. Notch7
    Notch7
    15 Sep 2017
    25,297
    Thanks Received:
    1,791
    S. Uplands
    Country:
    That makes sense to me.
    And, as Ive just done a garden cabin with PIR, flush to the top, Im rather glad its not wrong :)
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
