- Joined
- 11 Dec 2007
- Messages
- 406
- Reaction score
- 3
- Country
We're going to have someone come out and look at doing our bathroom (total rip out and start afresh job) and i want to have some sort of a clue before they get here and not just swallow what may be a load of garbage because it might be something the installer would rather not do.
Currently we have the bathroom how it was when we inherited it 5 years ago...
The house is a 1930s house with plaster & lath walls & ceiling.
The tiles are pretty flat except for that area that has gone black mouldy due to the silicone - the tiles have started i don't know if it's actually popping off but they're raised.
We've been told about the possibility of sheets and we're interested in this for ease of cleaning purposes (as well as probably a quicker install which may lead to being cheaper at the end of the day - though that isn't the main thing).
Q1: Are sheets decent enough or are they a poor option?
Q2: I'm told you can sheet on top of tiles. I've a feeling that this isn't really a good option though i'm clueless so i have nothing to base this on other than a hunch. Would it be acceptable to sheet on top of the tiles? I assume the raised ones would need to be removed but everything else ok? Just wondering how it'd also work around the window when you start doing that though.
Q3: Are there different types of sheeting? I've seen something (forget the name, splashback or splashwall i think it is) in B&Q though i imagine there'll be better value stuff out there (again - a hunch). If there are then what would you opt for and why?
Bit of extra info...
The room is approx 2mtr-x-2mtr & we'll be wanting the whole thing done. New floor, new walls, probably new ceiling (it's like a vinyl paper on there at the moment which stains with the moisture/heat), extraction, lighting, rad, units.
