This Christmas, I have decided to follow the cooking method used by thousands of people in the US and I am going to deep-fry the turkey. This will be done outside over a propane gas burner. You can read all about the plus points online (essentially producing the best results in a fraction of the time). Of course safety is paramount and I have researched everything regarding that.
To keep within budget, the only real option is to buy a very large turkey-fry pot made of aluminium. I am a bit concerned that a couple of reviewers have stated that they managed to burn a hole through the aluminium. This is obviously extremely dangerous but I suspect was the result of abusing the pan (heating it empty over an oxygen fed flame).
My question is: To improve the pan base, could I purchase a small sheet of stainless steel (3mm thick), cut it to size and glue it to the outside of the aluminium base using heat-proof glue - the kind used on car exhausts? Steel has a much higher melting point and would therefore protect the aluminium. Would the glue work or would the base just come away under the heat? Should I just trust the aluminium?
