I've got a 12V tension wire lighting run that's been in place for a number of years and works fine, running off an electronic transformer (I know that's problematic, but it was done before I moved in ...).
I'd like to add a LED tape run off the same lighting circuit as a fill-in. I did a little experiment with bits I had in, chaining in parallel an LED driver off the 240V feed into the existing transformer, but whilst the LED tape worked fine, the original transformer started buzzing and the attached lights flickering.
So any idea what I did wrong, and how should you run multiple 12V transformers off a single circuit ?
Thanks.
Thanks.
