I have a problem with my Baxi solo 3 50 PF.
In the initial instance when the CH or HW demands heat the boiler on indicator will come on, followed by fan indicator, fan starts, then pilot ignites, pilot indicator on followed by burner and burner indicator.
It will run like this for 5-10 minutes and then the burner and burner indicator will go out, the fan will continue to run for a few minutes and the pilot igniter can be heard clicking, fan will then stop and fan and pilot indcator will go out. boiler on light still illuminated.
Once this happens the boiler will not fire up again unless left off for some period of time. the water temp in the rads or the tank is just luke warm and the fault occurs weather i am wanting CH, HW or both
I have changed the PCB which did not cure the fault and also checked the boiler stat thermistor (reading 900k ohms at room temp) resistance decreases with heat.
I've included 2 pictures, first of which shows boiler indicators when first fired up, second shows lights when burner has gone out.
any ideas as to what may cause this?
