Central heating not working - Baxi Solo 2 50 PF
24 Mar 2007
Hi
We have Baxi Solo 2 50 PF boiler.
I wanted to test our central heating today to make sure it is working fine for the winters. I switched on the timer (EPS6002) to on position and boiler did not start. None of the lights on the boiler thermostat indicator would turn on (over heat, boiler on, fan on, pilot on, burner on). The water heating on the other hand works perfectly fine. Can you please advise what I can do in this situation?
The boiler was serviced last winters but is not under any contract.
Thank You
Pav
kevplumb said:
look at the 3 port valve first airing cupboard usually ;)
Hi kev
Thanks for your prompt response. I located the a three position diverter valve in the airing cupboard. it is from honeywell. It has one lever in front and is on the left side. What should I do with it.
Regards
Pav
kevplumb said:
well for now shot the lever over and lock it in the slot
this will give you hot water and heating
it needs looking at tho
Hi Kev
Thank you for your inputs. I moved the liver to the right and then moved it to the left again and the CH and WH are both working now.
Thank you for your advice is very much appreciated.
I will get the boiler check and I think it is time to take out the annual contract.
Much appreciated.
Regards
kevplumb said:
no probs fella ;)
Hi Kev
Sorry to bother again.
After adjusting the lever on the diverter valve yesterday today morning when the water heating started the Ch also got switched on and radiators were hot. The CH timer setting was on off, only the HW was on the timer.
Do I need to change the setting again on the valve? Which position should I keep it on?
Regards
