Installing DAB Adapter
26 Mar 2010
Worcestershire
The power requirements are 5V DC and they provide a cable yet this hogs the only power socket in the car. If there any reason it can't be run from a USB cable as per the satnav?
No it will work fine. If you want this to all happen behind the dash....
Would you wire the necessary plug to this or would you solder direct into the dab adapter? I am wondering if the pin out for the micro usb might be a pain and then you also have to fuse protect it. What's your view on those piggy back fuse carriers you can get?
A picture or model of what you are fitting would help. It sounded like you were fitting a pre-in to hang off the cars amp, but now I'm thinking its self contained.
These are from the suppliers stock imagery but shows the power socket on the back of the unit. It is only a small dash mounted head unit
